Flat Grind on Buck 110
Good day.
Who has a Buck 110 with flat grind in use - is there any noticeable difference in use with the classic razor grind?
Not a 110, but I do have the 2018 301 Blade Forum knife with flat grind, and a production 301 and a couple 371's with hollow grinds.
I don't notice any difference in cutting.
I mite be too insensitive to notice though, or I don't normally cut things that would have a noticeable difference in effort?
if they are the same stock thickness, which I'd assume they are, I dont think one would notice any difference between hollow ground and fg.
if the stock was thinner and ffg than maybe depending on what was being cut.
The model that would compare closely to 110, would be a 317 or a 334. Both of those are flat grinds and the blades near the size of a 110.
I've compared these, head to head w/ a Buck workman. Which has a thin hollow grind and found the difference to be slight. Dm
The flat grind is NOT a full flat grind like you find on a Case Sodbuster. It's actually closer to the Scandi grind of a Mora.
Similar to a Mora, it's a great heavy duty blade. It works wood really well and I would trust the edge to not damage as easily as a thinner hollow grind like most Bucks.
On the other hand, you really need to know how to freehand sharpen on a stone and need to be willing to scrub down the entire bevel of the blade like you do with a scandi. Otherwise, if you just continue to micro-bevel the edge, the edge will get very thick very fast.
Like a Mora, mine is a terrible sliver of things like potatoes but that's to be expected and is not a ding. This is a hard use blade, not a winner of tomato thin slicing contests.
I'm in the process of conveying and thinning mine. I wish they used this grind on some of their outdoor fixed blade where the power of the Sabre-flat grind could be used for splitting (like a Mora). In this way, I think the blade is too powerful for the 110 handle. I'm not going to baton a lockback. Perhaps at some point, I'll get mine closer to Opinel thin/convex and that would be dandy.
