flat grind vs hollow grind
can someone please tell me what this means..ive seen it time and time again on here. Are there pros and cons to both?
My biggest pro for flat-ground is that only 130 are made and they are signed by Chris Reeve ;):)
Ted,
That isn't 100% correct. There were probably closer to 140+ of them and I know for a fact that two of them came out of the shop without signatures on the blade. I have one in my collection and I know the other one ended up being "mayo'd". :D
Not likely to ever happen again, so I had to rethink my idea of using the unsigned flat ground as an EDC.
OK ;) Fair enough, I'll change it a bit then :D
My biggest pro my for flat-ground is that only 130 to 140 are made and most of them (including mine) are signed by Chris Reeve
Ted
I think that Raindrop is correct in saying that there were more than 130 flat grind blades made because the paper that came with mine states, "----------This knife is fitted with one of the first 130 blades that we have made.---------". I do believe that only the first 130 were signed and dated by Chris. Better yet, mine is a left-hand knife with signature and date on the right side of the blade. After checking with Anne, she confirmed that CRK had only sold a total of 5 flat grind blades in the left-hand version.
David
