I have only one example, the top knife in the pic.
It was quite challenging but fun and I learned a lot. I set the plunge by hand with files, then ground the bulk of the bevel more or less parallel to the belt, using the bottom (drive) wheel on my grinder as a contact wheel, getting to about 80% finished, maybe a bit more. Then I draw filed to get everything "flat" and even. Lots of draw-filing. Marker or layout dye will really make the low spots stand out. Then I sanded with 220 paper to get the file marks out.
I find it quite tricky, but rewarding. Don't try to grind as aggressively as you would a regular profile. Go slow and in smooth passes. I strongly recommend trying it out on a piece of scrap steel or wood before commiting to quality cutlery steel.
