I have seen a post on this, but can't remember where. It was just within the last couple of days.........maybe a week or so. May have been on the other forum (knifenetwork) It gave some pretty good info. Maybe a search would help.
Remember, many makers are grinding on a 2 inch wide belt, and are grinding horizontally. This means that only 2 inches of your blade are contacting the blade at any time (and even less toward the tip or any recurve).
If you grind vertically, and your grind area is a 6 inch long blade, the belt friction and resulting heat is greatly increased. Therefore, the time of belt-to-blade must be reduced with more frequent cooling cycles.
I can see how it might help with flattening a flat grind, or maybe even assisting in obtaining more equi-distant plunge lines (if you have a large enough flat platten and maybe using a pyro-ceram liner), however, remember that the side you are grinding is facing down, and you can't really see much of what is going on unless you are laying on a creeper and grinding overhead
Enough of my ramblings.........my pea-sized brain is starting to hurt.
