- Oct 2, 1999
Hey Guys!
I am sure that there are some of you who flat grind. This tip might help you.
I rough grind my blades on my 2x72 grinder
(on the flat platen) using 50 & 120 grit belts. From there on I grind on a disk grinder. I took apart an old 1x42 belt sander
with 8" disk and am using the disk only. I went one step further than most and glued a 3/8" rubber disk (not sure of hardness, probably comparable to a contact wheel) onto the aluminum plate. I just cut disks out of wet or dry sandpaper and spray adhesive onto the back and stick it on. once you trim it up your ready to start sanding. I recommend that you use lower RPM's. If you get too fast the rubber disk will fly right off (trust me).
Using the disk like this allows you to have better control and I find it easier to remove the deep scratches that flat grinding produces. You will have to practice with it in order get good at it. Give it a try!
Hey, $.30 - $.40 per disk is much better than
$3.00 - $4.00.
Barry
http://albums.photopoint.com/j/AlbumIndex?u=126319&a=926274
$3.00 - $4.00.
Barry
