- Feb 1, 2000
Help, I tried flat grinding a small 1/16" thick kitchen knife on my 4"x36" grinder and failed miserably. I ended up with a convex grind half way up the blade instead of a nice flat grind to the spine. I also burned the delicate tip right up!
Obviously I lifted up too much on the handle during the early stages of grinding but the flat grind seems to elude me. Do you lay the blade flat on the grinder and then apply pressure towards the cutting edge or do you try to hold the blade at the 1/2 or 1 degree incline and then lower it onto the belt?
Thanks for the tips in advance (I'm suspecting that it might actually be harder to grind very thin blade stock than the heavier blades!)-Guy Thomas
