Flat vs. Hollow Grind - Visual Appeal
I have followed for some time the statements that a flat ground blade is superior to the hollow grind. I realize and have no objections to this; HOWEVER, visually I find the hollow ground blade to just LOOK better than a flat ground blade. Realistically, for 99% of what I use a knife for, there is no difference between the two. I find I can sharpen one just as easy as the other and they will hold the edge just as long. Show of hands here: how many of you like which kind VISUALLY! Oh, my ideal Spydie, for what it's worth: a black micarta Calypso Jr. with a plain edge hollow ground blade. Apparently this is not an option!?
I agree that hollow grounds are visually very appealing. I really like the hollow ground on the Native for instance.
i could be in the minority here, but i love the look of flat grinds. it is just plain and simple. i have a micarta calypso jr. and love the way it looks. contrary to you guys above me, i'd love to see a native in flat grind.
I think the hollow grind looks cooler.
I don't believe that the flat grind is always superior to the hollow grind. One need only look at the Sebenza blowing away its flat-ground competition in performance tests to see what a hollow grind can get you. It may not be the perfect grind for deep cutting, but for shallow cutting, it wins easily.
Although I prefer a full flat grind for general use, I have no problem with the idea of a hollow grind *especially* on folders, where I'm not going to be chopping, and shallow-penetration performance is really really important. Certainly, if you're not going to do a full-height flat grind, on a folder I'd pick a hollow sabre grind over a flat sabre grind any day.
An afterthought. A lot of the bad press about hollow ground knives is based on experiences with the old Buck-style hollow grinds. This was a hollow sabre grind, but it flared back out at the very edge. So you had all the disadvantages of a hollow sabre grind (rapid, non-linear expansion of the edge), without the hollow-ground advantage of an incredibly thin edge. Anyone who has experience with a properly-done hollow grind will think much more of it. Again, still not my choice all the time for general use, but a hollow grind definitely has its place, if done right.
Joe
jat@cup.hp.com
[This message has been edited by Joe Talmadge (edited 12 November 1999).]
What Joe said!
I might add that I prefer the look of a flat grind probably for it's simple but capable look.
If a person with multiple personalities threatens suicide, is that considered a hostage situation?
I also prefer the flat grind for looks. I think it just looks more elegant; simple and clean without grind lines to distract your eye from the overall blade outline.
Not only is the flat grind more visually appealing, it reduces the force required when making a deep cut.
Dale Richmond
AKTI Number A000949
