I have a 1st gen MT LCC and a Strider SA with flat ground blades. I carry the Strider all the time, and have cut A LOT with it. My sm. sebs just cut like razors! I even totally polished the blade on the SA, and I still prefer the Sebs blade. I do, however use the SA for hard use though...stuff better suited for a fixed blade. The flat grind is a good cutter. I've used the SA A LOT. I have sharpened it dozens of times. I've sharpened it enough times to have reprofiled the 1/16" tip I broke off back into a point. IT DOES get harder to sharpen. I feel like sooner or later it will look like an axe's blade! Actually, I like the knife enough that I would have it reprofiled to an efficient thickness if it ever became a problem. Looking at my LCC, I see that it's blade is actually very thin at the edge and nice and sharpenable at least a 1/4" through the metal. COOL! The geometry of the triangle allows a very very fine, yet strong gring angle, it seems. The grind actually goes to and makes up the edge, almost like it's ground to an edge and just touched up on the edge to make it look right. This obviously adds a very fine sharpenable edge space to be, unpresent on hollow grinds! Hmmm. I'll have to think about this. Thanks for the enlightenment, fellas!
