Oh yeah. I was a machinist for 20 years until my back gave out. I have a nice cast iron lapping plate about 13" x 8" that I brought in to the shop and surface ground to reflatten it - after being used in a toolmaking shop for a while it had about a .002" hollow in the middle. I can flatten just about anything to within less than .001" using loose silicon carbide grit - and the nice thing about doing it with loose grit on a lapping plate is you don't ever have to worry about the cutting speed slowing down - you just sprinkle on a 1/4 teaspoon more grit and you're good to go just like the first time you ever used it. I've flattened granite plates, float glass plates, Arkansas stones, all my waterstones, a Spyderco UF bench stone, all sorts of stuff - and I've only used the first side (mine's double sided). Checked it the other day after about a couple of months use and still can't get a .001" feeler gage under a precision straightedge anywhere. It's important to try to use the surface evenly so you keep it flat as long as possible if you want to use it much. Some folks try a sheet of wet/dry on top of their lap or granite plate and use loose grit on top of that to try to prevent wearing the lap but I've found that just using the lap works great and gets things quite a bit flatter also. I can lap two items and put the lapped sides together and can't see any light through the interface. Using a sheet of wet/dry tends to roll the end up a little and give a surface that's pretty flat in the middle but a tad convex around the periphery.
