- Mar 1, 2010
Will wet/dry sandpaper over glass work?
You don't need the special Edge Pro Round Glass kit. You could buy the 1/2lb bag of Silicon Carbide
Simply use abrasives over something flat, which means Sandpaper would work. Make sure you buy Silicon Carbide infused Sand paper
Yes, it will work very well. So will flattening on a 'decorative' (so it's a bit smoother than the building type,) cinder block or a smooth cement block from a DIY shop.
Stitchawl
Any suggestions as to grit size?
