I heard these are pretty wear resistant. I am sure over time they need more that just conditioning with a piece of nagura corrective stone. There's a difference between conditioning and flatting . So if there's only 1mm of abrasive you really don't have much room for lapping much?? Or is this abrasive pretty darn hard? Anyways how do you recommend flattening whenever it gets dished i assume it will eventually need lapping back to 'true flat' again. Looks like you could only lap maybe a couple times before its done, because 1mm isn't much abrasive?!! I read that sic can be used on glass. What grit Sic do you recommend for the grunt work getting it flat? After its flat what grit sic would you recommend to finish/condition the final surface finish to on the 600 diamond resin?
Also can a diamond plate like a dia-flat dmt plate be used instead of Sic? Or would this ruin a diamond lapping plate if used on a diamond resin stone? I got a feeling it will ruin a diamond plate, it would be like two cats scratching each other at the end it will flatten it but it will trash the lapping plate. Sic doesn't lap as accurately as a diamond plate, there's usually a little bit of a crown in the stone whenever lapped with sic, but nothing is perfect. Any suggestions please
Mike
Mike
