- Jun 8, 2000
I've been fascinated by knives since I was about eight years old as far as I remember, but it may actually go back farther than that. I had a metal shop teacher in Jr. high school who made custom knives. His name was Steve Linsday. He also got me hooked on metal working. From there I kept taking metal shop through the rest of Jr High and high school eventually ended up as teacher's aid in the Vocational classes. I did machine maintance, hand ground lathe cutting tools (including threading tools). After I graduated I went to work as an aprentice machinist for about 18 months and discovered a few things about my self. First, Working in a production shop, I learned that I get bored tapping the same hole in the same spot on 10,000 of the same casting. Second, I'm a social animal and at least at 19 years old, was not good at only talking to my machine for 60 hours a week. Third, I wasn't good enough or patient enough to hold the tolerances required at the prototype/ limited run shop I had finally worked myself into at that age (about what Chris Reeves works with, .0002/inch). This knowledge helped me decide to leave the metal working business and pursue a career in sales where I've been for most of the last twenty years (hifi gear).
After all this time talking to people I'm ready to start talking to machines again. I need to take my knife obsession to another level and stop buying them and start making them. I'm at a point in my life where I really need a creative outlet and my obsessive personality and attention to detail lead me to believe that with a few years practice, I might make a few passable knives.
Here's where I need the help. I know my way around a shop pretty, but don't have one (yet). What do you think I'll need to get a reasonable start? I'm thinking to get started I'll need the following:
1)A decent belt grinder/sander specific to knife making.
2) a small vertical bench mill (have looked at a vertical mill/ lathe combo at harbour freight for about $700.00, any opinions here?)
3) Bench grinder (have one)
4) Drill press (have one)
5) assorted measuring and layout tools
6) assorted files/stones/ other abrasives
7) buffing wheels and rouge
8) surface grinder (in a perfect world, prob not to start)
9) Small hydraulic press?
10)Lots of good advice and tutoring,(any interested knifemakers in So Cal?)
I'm guessing I can put together most of the above for less than $2000.00 (without the surface grinder). Have I missed anything? Does one start with cold rolled steel to get the hang of this, or do I order up some ATS 34 and hope for the best?
My first attempt will likely be a stock removal neck knife (smaller pieces of scrap if I mess up a couple). What does one do for heat treat? I've looked at a couple grinders at Koval Knifemaker Supply, any opinions here? I also saw a 1000 grit 8" wet wheel machine at Harbour freight for $100.00 any opinions here. What about their bench mill, is it of any usefullness? A used Bridgeport would certainly be better, but much more money and space in the garage.
Let me know what you guys think.
jmx
jmx
