- Oct 22, 2012
Does anyone know how Flexcut Gold compares to the DLT compounds, i.e., what is Flexcut Gold similar to (black, green, white)...?
( From site -->: http://www.flexcut.com/products/cart.php?target=product&product_id=975&category_id=95 )
"Designed for quickly maintaining a sharp edge, Flexcut Gold Polishing Compound has been specially formulated to apply like a crayon. Its blend of aluminum and titanium oxide provides a balance between aggressive removal of hardened tool steels and offers a high-color polish. "
( From site -->: http://americanmachinist.com/features/all-about-abrasives )
"Brown fused aluminum oxide includes 2 to 4 percent titanium oxide (TiO2) to enhance toughness. (Titanium oxide is also known as titania.) This is the most widely used abrasive, and is used to grind high-tensile-strength materials, and for rough grinding, deburring and snagging, as well as to cut low-alloy, ferrous materials."
(and another quote from the same source...):
"Low titania brown fused aluminum oxide has 1 to 2 percent TiO2 content, and is used in bonded or coated applications that require an abrasive that is slightly tougher than white aluminum oxide. Reducing the titania content reduces the abrasive's toughness, but increases its friability."
According to Flexcut's own description, Flexcut Gold is a blend of aluminum oxide and titanium oxide:
The 'blend' description would make it difficult to directly compare to other compounds, i.e. 'white' or 'black' or 'green'. Don't know a lot about titanium oxide, but I'm finding a few references describing it as an additive to enhance the toughness of other types of aluminum oxide abrasives. By 'toughness', I assume that means it's ability to resist breaking down (fracturing) during use, into smaller particles, which some aluminum oxide abrasives will do (that property is called 'friability'). The quote below is in reference to utilizing titanium oxide with brown aluminum oxide specifically (maybe this is what's used in the 'Gold' compound, but I don't know).
I would assume, at the least, that the aluminum oxide might vaguely compare to some (but not all) other 'white' aluminum oxide compounds, which can be very aggressive (larger particles) or high-polishers (smaller particles). But that's hard to pin down, without actually trying it for comparison. Even that segment of 'white' abrasives is a very wide range in itself.
Member HeavyHanded has used it, and described his impressions of it in this thread (links directly to his post in that thread):
http://www.bladeforums.com/forums/s...uot-guided-quot-route?p=11035568#post11035568
David
Man you are good with the search, and even better with the memory!
I've never used the DLT compounds, but Flexcut compares very closely with Ryobi yellow. Its hard for me to judge where different compounds fit in the scale without using them on hardwood in a slurry - this eliminates many of the other variables in my opinion. The Sears and Ryobi white compounds are a touch more refined than the Flexcut as I use them, but not by much. Its pretty fine stuff - with the right backing it'll get close to mirror finish. Its the last compound I'll use if I want any tooth left on the edge.
Thanks for the input/info. I will just have to strop away and see how they compare. I've been using the Flexcut, which I like, but I am about to try the DLT green and black compounds.
Thanks again!
