Hey guys. this post is to gain a little knowledge. Why did Jerry put the flat side of his grind on the outside of the blade (outside meaning to the right side while facing the spine). I know that this edge design was to make the edge stronger and easier to sharpen on top of everything but it seems to be on the wrong side to me. I am right handed, (I figure most of Jerry's customers are... no offense to you lefties out there) and when I sharpen my knives I do it free hand sliding the edge across my bench stones. Being right handed it is easier to lay the blade down and slice away from myself to get the inside and slice towards myslef (YIKES!) to get the outside of the grind). But with this grind the side you sharpen is the one where you must slice towards yourself, which for me and I assume all other righties is the more challenging of the two sides to hone. Perhaps I am just strange that way. It just turns out that the only side on a Busse that one must hone is the hardest one for me to work with. By having it in this configuration does this yield the best cutting performance or is that just the side Jerry Picked. what do you guys think. I am just now getting to the point to where I can restore my factory edge. But it is still a challenge every time I do it. Seems like having the flat side on the inside of the blade would have made it a joy to shaprpen and a whole lot easier for 75% of Busse customers (pulled that number out of the air by assuming 75% of us were righties). And maybe I am just a retard when it comes to sharpening. But it has always seemed to me that the inside of the blade was the easiest to sharpen cause you push the edge away from yourself and you can constantly see how much air is between the spine and the hone keeping your angle exact and minute rice perfect all the time. And the same goes for stroping on the other side. Since you go edge trailing you can safely pull the knife away from you. Just a thought. what do you guys think?
First impressions are usually the scale by which we are judged unless we make our second with something sharp and pointy.
http://albums.photopoint.com/j/albumList?u=879893&Auth=false
