- Jun 12, 1999
i'm building a flood coolant system from a 1/4hp pump for coolant with a 5 gallon resivor. i plan on using 1/4" npt hose with a magnet base manifold. at the manifold their is one out put, using y connections i'll split it 8 different ways. each smaller hose will go to a flexible hose that has a 1/4" nozzle.
each hose will be for a different part of the wheel. i was thinking two nozzles in the front, two in the back. two on the left and two on the right?
my questions are, is this enough coolant to cool down a wheel? i'm switching to a diamond plated wheel, becuase they are cooler, so that should also help keep it cool.
will a 1/4hp pump work? or should i put a 3/4hp motor on it? is a 1/4" line big enough to supply enough coolant for 8 nozzles? or should i switch to 1/2" or 1"?
should i get nozzles that taper from 1/4" to 1/8" or will 1/4" untappered have enough velocity?
thanks in advance.
thanks in advance.
