- May 3, 2006
The area I live in is under a very high risk of severe flooding this fall/winter and Im coming to my WSS brethren for advice & insight. I know many of you have had to deal with flooding in your areas and may have valuable advice.
I live in the Green River Valley south of Seattle. Damage to an earthen bank adjacent to the Howard Hansen Dam has prompted the Army Corps of Engineers to decide to reduce the storage level behind the dam to one third of its usual capacity. This means they will be letting out a LOT of water in order to protect the dam from catastrophic failure. To add to the mix, many levees on the river are substandard or in bad shape, and are not expected to withstand the increased water. Finally, the valley is very close to sea level, so high tides can bring the rivers outflow to a near standstill. The cities of Auburn, Kent, Tukwila and Renton are in the downstream path between the dam and Puget Sound. Here is an article on the situation.
Our two-story townhouse is not on the valley floor, and I believe we are sufficiently high to avoid actual flood waters except in a biblical flood. One concern raised is sewer backup causing flooding inside. The countys newest jail complex is in the valley, and part of their response plan is to release a lot of prisoners rather than evacuate them prior to flooding.
While our home is not on the valley floor, my wife works at Boeing, which is. They are taking the threat so seriously that they are spending 26 Million Dollars to build a 6 foot wall around their Kent campus in an attempt to keep flood waters at bay. If that fails, who knows how long she would be without an income. (Im currently out of work so this would be financially disastrous.)
So, given what I have outlined above, what should my concerns be? What should I be doing to prepare? If flooding does occur, which looks rather likely, what can I anticipate? (I am not completely unprepared and I havent just started thinking about this, but I thought bring this to you guys would generate some good info.)
Thanks,
-- FLIX
Thanks,
-- FLIX
