- Feb 20, 2003
FMa stick techniques and sword techniques. Has your instructor taught you both? And do you know the difference?
Some of you might be curious why I have sword and stick as separate techniques. IMO, yes they are similar but not all of the concepts are interchangeble. Weight, length, the presence of a sharp edge/s and point, and sheath are factors that need to be kept in mind.
The weight difference between a barong with a 16" blade and a 26" rattan stick is significant. Imagine a 26" sundang or ginungting instead of the barong and the and the centrifugal energy another 10" of steel creates. It's tough to quickly redirecting something of that size and weight one handed. This supports the idea of training with kamagong or another dense hardwood. Such harwoods in 24"-28" length and 1"+ diameter best imitates actual blade weight. If you struggle with they heavier weight, there's no way you could efficiently wield a sword.
Everyone cuts thier sticks to thier preferred length which on average is @ 26", with the exception of Serrada eskrimadors. The very rare kampilan is the longest of the indigenous blades averaging 32" OAL. Sundang, talibons, and ginungting all fit the 26" criteria but they are hard to find and expensive. Commonly available swords are kris, bolos, and barongs. They rarely come close to 26" and usually average 22" and under. 4" isn't very much but keep in mind how fast and what it takes to move 4". One man's largo is another man's medio . . . and so on. It is much easier to go from the "in" to the "out" than vice versa. Train with different weapon lengths and don't get stuck with initial contact distance pre-set in your mind
I rely on footwork and parrying in defense. Force on force blocking isn't something I would consider with a sword but still an important skill. Failure to keep track of the edge/s and the point are the swordsman's demise. Most FMA practitioners have a tendency to "roll" thier stick during blocks. This is evident if you "present" your knuckles in the direction of a strike. Had it had been a sword instead, the edge would have been put in the path of the incoming strike and taken significant damage one possibly broken. Now imagine trying a supported cross block form an incoming #1 or #3 strike but with a double edged sword. Get the picture? Properly blocking with the flats or spine is an important skill that needs to be practiced and can only be done properly with a sword or trainer with obvious sword profiles.
How many of you have ever drawn your stick/s from a sheath attached to you? That's what I thought. The entire sheath factor is my weakest attribute. I have no problems with blades 10" and under but anything over 12", I'm awkward and inconsistent. I used to think my arms were too short but I think of all the men I have seen draw an 20" sundang efficiently, most were under 5'5". I guess I just haven't practiced enough. I can't imagine having to draw under high stress situations. I'd be much better off carrying my sword in my live hand but that defeats the entire pupose of the live hand.
Take all of the above mentioned and imagine yourself in the 18th century. It doesn't matter where. Is your current training enough to have kept you alive in combat. If it isn't, you owe it to yourself to change it.
Your replies, suggestions, criticisms, insults, hell, anything you'd like to post is welcome. This forum is getting stagnant needs some reviving. A little stimulation, conversation, and confrontation will do us all some good!
Dayuhan
Dayuhan
