C.L.A.K. thank you for reporting your lack of problems so far with that sheath. I like the "no fasteners" idea for kydex sheaths. Much sleeker than the pancake sheaths with eyelets or rivets on both spine and edge sides of the sheath.
To further secure the folded-over flap of kydex, you might want to weld it in place chemically with tetrahydrofuran (known as THF for short, see below).
WARNING!! Tetrahydrofuran in incredibly nasty stuff to work with/around. Be sure to read the Material Safety Data Sheet (MSDS) on it before you use it. You can find the MSDS for THF online. Apply it to your kydex outdoors if you can (for vapor dissapation) and don't have it cure in your house if it is avoidable (like put it in garage/shed).
info below cut 'n pasted from an old posting of mine
Tech support at Kleerdex, the manufacturer of kydex, recommends using tetrahydrofuran (THF) to "weld" kydex pieces together. THF is a PVC solvent of some sort. Cure time will depend on amount of THF applied, amount of moisture in the air, and temperature at which it cures. At house room temps, the engineer said to give it about 24 hours, so this is not a real quick curing solvent.
According to the guy at a local plumbing supply house, there's THF (plus methyl-ethyl-ketone aka MEK) in a multi-purpose plastics cement made by IPS. That might work for chemical kydex welding. Other such plastic pipe welding cements/adhesives may also have THF in them.... check the label listing of active ingredients to see which ones do.
