Folder angles...
Bapple
What angle to most of you put on your EDC folders? And why do you choose that particular angle? Just curious.:thumbup:
I like 15 degrees per side for medium quality steel, and 10 degrees per side for top end steel. :thumbup:
"Truck Stop Special" $9.99 per copy knives get 25 degrees per side.:p
The smasller the angle, the better they cut, but the weaker the edge will be if the knife is abused.
My ZDP, M4, S90, Carter Necker, go 13* because 13 can't be unlucky for everyone. It seems to be a good angle for top end steel, the way I use it, which is damn carefully anyway.
S30, VG10, D2, A2, etc. go 18*, and I use them the same way.
I can cut most stuff without edge failure at those angles, although I admit I'm not above micro-beveling slightly when I've been too rough on a blade. I think it's a matter of figuring out what each blade can do without microbeveling.
I will use a knife that has a micro bevel as a "hard service" knife, so I normally carry one of each type. One is kind of to show off an edge, one is used for most cutting.
gg
I'm not yet completely conversant with ZDP 189, so I won't address it here.
CPM M-4, CPM S90V and VG-10 have given me excellent service at 10 degrees per side.
Like you, I use a knife with the same care I use with other precision tools. That is to say, I use it as a knife, not as a hammer, prybar, screwdriver, nail-puller, etc.
Try 10 degrees sometime. I think you'll be pleased with the results!
I've been doing 14 on D2 and 154CM, 9 on ZDP, 18 on AUS8, 420hc/440c are at 20.
Don't own many other types of steels ATM.
gg
Thank you BD,:thumbup: but I use my knives on hard wood and hard plastic at times, and I need that extra amount of durability and edge holding. Even at 13* I get edge deformation and micro chipping occasionally, and it really bothers me to grind some of that stuff back out. I feel like I use my knives up too quickly going lower. I trust it works like magic for some folks, and I do have knives at 10* for times when I'm carrying two knives. :D
