I have checked my drill press table and it is good..less than 3 thous in 9 inches. I assume that is good. I begin by drilling the pivot small and gradually drill larger and finally ream to size. Pivot fits tight. I hand lap the steel blade between machining operations so that there is no burr to ride on. I just can't figure it unless the lock is pushing it over...but even if I tighten up the pivot screw against the washers and liners it is still off center...not by much..but enough to not look correct. Any suggestions? Thanks
