Will; first of all, Cliff takes issue to nearly everyone sooner or later; that is what makes the forum so valuable; all of us agreeing would be stagnation.
However, you misquoted me. I said that the really important difference for (Bronco was...). This was because he was having a folder made, and corrosion resistance is important in a folder. I did NOT say the primary performance difference was.....
Look at the composition of the two alloys, CPM 10V is: C 2.45%, Cr 5.25%, V 9.75% Mo 1.3% CPM 420V is C 2.2% Cr 13% V 9% Mo 1%
To me, the main difference between these two alloys is the Cr concentration; it is nearly 2 1/2 times higher in CPM 420V. I agree that a lot of that Cr (but NOT all) will go into softer Cr carbides; 10V will have more V carbides, so will probably have better wear resistance. Hmmm...let's go to the CPM site:
http://www.crucibleservice.com/cruplas.htm
By golly, I was right! 10V DOES have better wear resistance than does 420V.
Further, CPM 420V is less tough. Hmmm... not sure why, but there is less C and Mo in 420V, and this could influence toughness.
However, I still think that the main consideration in a folder, which gets liquid in crevices, is corrosion resistance. Walt
