FOLDER MAKERS... how much clearance for pivot holes?
I posted this over in custom knives and guns but I wanted to see what you guys had to say also. I have some .1875 pivots , and drilled my pivot holes to .1870 and reamed with the .1875 reamer. I then chucked up the pivot in the lathe and spun it on some 2000 grit till I could get the pivot in the hole. Still fairly tight friction fit, I can push the pivot in with my fingers but I cannot spin it (unassembled in hand). How tight is too tight? My clearance is probably .001 (just throwing a number out there for that one).
So should I stick with what I got and spin the pivot with the 2000 to take a couple thou off or maybe ream to a .1890 (actually looked for a .189 reamer but found .188)? Or would that be too sloppy?
I use a 0.003" clearance, so if your pivot measures 0.1875", a 0.188" reamer should do the trick.
I may be wrong, but this has worked for me. :thumbup:
You can sand off a few tenths (.0001") fairly easy, but you're not going to sand off a few thou (.001").
I think ideal clearance would be under a thou. A .188 reamer should be perfect.
Our 3/16" pivots are machined to .1870 (+.0002" -0.0000"). We recommend knifemakers use a .1875" reamer. The pivot has raised shoulder of .1875" so it can be press fit into the liner.
You mention that you can't spin it.
IMHO, you want a captive pivot pin, either by staking on a flat or the press that Chuck Bybee mentioned
The only thing spinning should be the blade on the pivot pin, when you open & close the knife ;)
:cool:
It's getting tougher to find on spec precision pivots. i use pivots that are turned to .1870.., and use a .1875 reamer. order from the Bybee's and you'll be all set!
I have seen the pivots on your site, they are pretty sweet.
:cool:
I guess I should have mentioned that the pivot pin is a barrel and not a press fit like the ones AKS sells. When I had said the fit was tight that was pertaining to the pivot hole in the blade itself. Once again not passing on all of the pertinent information. My bad guys...
I have a good idea now of what clearance I need, so another reamer purchase is in order. I found a couple places that sell .1880 reamers, that gives me .0005.
Just grab the pivot in a tap handle to hold it and buff it till it shines. You can also wrap a piece of sand paper around a round file and just give the pivot hole in your blade a couple of turns polishing it. That's all you should need.
No problem :thumbup: ;)
When a hole size is within a .0005 or so undersize, I've had the best results using a barrel lap. Load it with some clover compound or diamond paste and sneak up on a perfect slip fit.
Here's an excellent link for reasonably priced Barrel Laps @ $4.79 for a 3/16"
http://www.moldshoptools.com/catalog/list.php?category_id=102
Just trying to help here ;) , FWIW, you can easily isolate your barrel type pivot pins by milling (or grinding) a small land or flat on the very end of the pivot pin, then "staking" a flat into the applicable liner.
EDIT TO ADD : (since Chuck was posting the same time as me)
Or, what Chuck said :D ;)
:thumbup:
