- Feb 4, 1999
Question on folder pivots (yes, I know, my desire to do a folder rears its ugly head every few months)... how tight of a fit should there be between the blade and the pivot, and the pivot and the scales/liner materials? Every folder I own has just a plain pivot with screws holding everything together (as opposed to bearings and such). So, I feel like there must be a little play between the hole in the blade and the pivot pin, otherwise if the fit is too tight it would rotate the whole pivot assembly back and forth, no? So on a 3/16" outer diameter pivot pin, I have the recommended drill bit that is slightly undersized and the reamer, but is that going to make too tight of a fit?
I was talking with a maker at the knife show a couple weekends ago and he had this mega huge tactical folder that he makes as something diofferent now and then. He said there is some slop inm the works and when it all fits together the slop is gone. The knife felt perfect to me, no slop, perfect lockup, etc.
Also, I'm still sold on a framelock with a Ti frame. Is it even possible to use 6Al/4V of that thickness and cut it with dremel cut off wheels and such? Finally, does anything need to be done to 6/4 to harden it for framelocks?
