- Feb 4, 1999
Well, I couldn't wait for this bandsaw that it supposedly coming from Harbor Freight (going on two weeks now), so I took out my trusty hacksaw and started in on my titanium slabs last night. I drilled, reamed, etc my pivot pin location for the 7/32" pivot pin, and for the 3/16" stop pin. My progress is good in that the lock side of the knife has a nice press fit for both the pivot and stop pin, and I have a nice "slip fit" for the show side of the knife. Everything lines up perfectly, and so far so good.
The problem: the only stock I had in the right width was 1084. Drilled it, reamed it, etc and there is a lot of play with the pivot. Used the same bits, procedure, reamers, etc. There is a bit of a warp in the steel, so is that enough to create play? It has a nice slip fit, but it wobbles all around on the pivot. I bit the bullet and ordered some precision ground O1, so I'm hopinh that fixes it, but other than not having flat stock to start with, is there a reason the steel wouldn't ream out to the right size using the same tools (heat expansion something like that?).
