The blade and the knife itself are designed for combat, hence the name Combat Karambit. The commander and 7 variants are better for EDC.
I've never had a problem with a lock on my Emersons. I've owned 7 Emerson folders and have never had an issue.
This.
The hawkbill shape is not good for subdividing a sandwich. It is, however, good for subdividing a man.
That being said, I've found that the Tarani karambits by 5.11 are better folding combat karambits. They have better fit and finish, better lockups (they're lock backs), and more strongly curved blades (good for joint manipulation).
I have one of Emerson's folding karambits, and the lock was faulty from day one. Sent it back, and it returned with the same problems. I eventually had a custom folder maker fix it for me. I might just be really unlucky; who knows why I got a bad one.
The lock would visibly slide across the lock face with minimal pressure on the back of the blade. It moved enough that I was worried about it unlocking.
I can see where that would certainly be an issue.................
I carry two Combat Karambits, one on each side, for EDC in the city. Under 3", so I don't run afoul of any local 3" rules no matter where I happen to go. I use to think the K was just some gimick, but after some experience with them, they are one of the nastiest edged weapons there is! It's all about disabling your opponent by cutting and slicing tendons.....leave them laying there like a useless rag doll! If you don't understand this, you will never understand this weapon....
For utility, they are useless, so I don't carry them out in the bush or woods.
I have a dozen + Emersons, and no complaints of any kind about locks, construction, materials, or anyting else!
