Odin's Son
Banned
- Aug 29, 2013
Hi, new here. Reading through threads and seeing "use my folding knife as a pry bar" or such. I'm curious as to what you guys are prying open as I have never used my folding knife as a pry bar.
Knives are tools. But more specifically they're cutting instruments. Nothing more. Using a tool for anything other than its intended use is detrimental. So when it comes to opening paint cans I'll use a flat head.
Welcome to the forums.![]()
Knives are tools. But more specifically they're cutting instruments. Nothing more. Using a tool for anything other than its intended use is detrimental. So when it comes to opening paint cans I'll use a flat head.Welcome to the forums.![]()
Remove weeds from the stone tiles in the backyard. Opening paint cans. Use it as a wedge and hammer it between a window and window sill which was stuck. Use it as a screwdriver. Use it as a small shovel to free the last bit of sand around a drainage pipe. Use it remove staples from a cupboard.
That's the beauty of a cheap knife. If it breaks, buy another. So far my Chinese Axis SRM 763 is still locking up solid as if it was new and hasn't closed on me once.
I'm gonna order another few.
I was thinking the same thing...I thought you only use the tool for its intended job. I use a paint can key.Aren't flatheads for screws?![]()
Yep, looks like the things a kid would do with a knife..... Get a friggin screwdriver, or, heck, a mini prybar!!!!! They make those.
Knives have blade for a reason. If you notice the thin, pointy part at the end, it's called a tip. It's for fine cutting and piercing. Look at the flat part of a screwdriver now. Look at it, think about it, and compare it to the knife. You might now start seeing the difference, and why.
Unless you want them to look the same in very short order, DON'T PRY WITH A KNIFE!
