Folding knife for a sailor, part II
Thank you for all of your responses. My Spyderco is an older Delica, and the blade says it is AUS-8A. The corrosion is just a small stain near the tip that grinding does not remove. Likely some boat chemical, as much as salt air.
Yep, a fixed blade would work better. But I'm looking for a knife that I will carry every day for general use. It just so happens that my everyday knife gets used a lot on the boat, because it is always at hand. Others have already fussed at me for not using the right tool for the job, every time. What can I say? If I didn't (ab)use my everyday knife for so many purposes, well .. then why bother carrying it? I hope this doesn't make you aficianados cringe much. A lot of us who don't know 440C from soft steel view a pocket knife as a general purpose tool, likely the only one we carry day in and day out. At a business meeting in a suit and tie I will use it to cut an apple. On the boat in shorts, I will pull it out to trim line. I'm not changing my habits, just looking to renew an old tool.
Based on your responses and other research, I think I will purchase one of the Boye folders. All reports say these are very nice knives. Most likely, I will go with the dendritic steel blade, since some reviews on the web indicate that it is stronger and holds an edge better than the cobalt.
Here's something that puzzles me: Some knives I considered had their pocket clip facing the wrong direction, that is, with the blade pocketed point down rather than point up. Easy one-hand deployment is important to me, and I don't understand the reasoning behind the backwards clip.
Comments still solicited, and thanks again for all your help.
rturpin welcome. Tip up vs tip down is something that will get a lot of strong responces here at least you picked the right one tip up.
Be careful ! Calling a tip-up clip "upside down" would be like calling lefties "backwards" on a forum like this ! Many flamewars have been fought over this, or lesser issues.
Seriously, I like my clips to orient the knife point up, as my Spyderco lockbacks (like your Delica) do. Point-down clips sometimes allow a real deep ride clip, if mounted in front of, or over, the pivot pin. Most of the tip-down knives you see will be liner locks. The reason for that is that a liner has no backspring (like a lockback would) to keep the blade closed under pressure. So, even if a liner lock has a deep ball-detent to keep the blade closed, the possibility exists that in a tip-up position, the blade might open slightly in your pocket and you would get bit as you inserted your hand in your pocket. Once you develop the familiarity of your carry knife and/or the awareness of which knife you're carrying, one hand opening should be instictive either way.
Originally posted by Walt Welch:
You surely are not advocating a sailor's knife without a marlin spike???
Walt
Yep, I am. (a) The knife in the rigging bag has a marlinspike. (b) Most rope is now double-braid. I rarely splice laid rope. The tool I use for splicing double-braid is a lot uglier than a simple marlin spike.
Hi rturpin !
Can you tell (and maybe show too) what is the tool you use for splicing double-braid rope ?
Regards,
MIKLE
Originally posted by MIKLE:
Hi rturpin !
Regards,
MIKLE
I use Brion Toss's splicing wand. It's not required, but it is made for the job, and it works well. Splicing double braid is a bit tricky. Don't worry if it doesn't come out right the first time or two. Brion's website is: http://www.briontoss.com. You can also find it in the West Marine or Boat US catalogs. It's pricey. But it's nice being able to splice your own eyes.
rturpin:
Send me e-mail at fkrow@snet.net I have Boye folder with dendritic 440C steel, older model with black micarta. I do not use the knife and will sell very reasonable.
Regards,
FK
rturpin,
Thank you very much for interesting and useful for me website.
BTW: IMHO spike of Victorinox "Skipper" (or "Mariner") better then tradition: parallel-core rope and steel cable splicing quite easier (for me).
Last summer I kept aboard SpyderWrench (in no salt condition) as utility/multipurpose knife: first results and impression are not bad.
Regards,
MIKLE
