- Nov 25, 1999
<center><font size=4>Folding knife size efficiency.</font></center>
The knife is the tool for cutting and we do it with the edge. The blade holds the edge, the handle holds the blade. In case of a folding knife the handle has also another purpose, it has to accommodate the blade in closed position. Naturally it should be longer than the blade, the question is just how much longer? In another words, how large part of opened folding knife makes up the blade and how large part of the blade makes up the edge? In my opinion these parameters are pretty important to evaluate knife design quality. Of course their importance shouldn't be overrated and taken as the main or especially the single criteria choosing a knife...
For long time I was curious to compare size efficiency of some folding knives made by top-notched knife manufacturers. It is difficult or even impossible to do it looking onto factory specifications because manufacturers are applying quite different methods to measure for ex. blade length. So I decided to compare them measuring all knives according the same method.
For my review I selected some knives which I have or I had an opportunity to measure by myself. I excluded from this review the knives with manufacturer declared blade length less than 3" because the small knife designs quite frequently are influenced with somewhat another reasons, for ex. handle's minimal dimensions for secure grip etc. Here I also noticed some funny phenomenon and had to make some exclusions. For ex. SPYDERCO Delica's blade length is declared as 74 mm (less than 3") but really it is noticeably longer. On the other hand, Katz Knives Black Cat Ltw. has claimed blade length 3 inches but really it has shorter blade. I also excluded knives there the proper grip places user's finger(s) directly onto the blade, like in the SPYDERCO Calypso Jr. In this case the whole my measuring method would be wrong because the part of the blade in fact serves as handle.
<a href="http://albums.photopoint.com/j/View?u=222944&a=2716881&p=25604201&Sequence=0" target="_blank"><IMG align=right SRC="http://albums.photopoint.com/j/View?u=222944&a=2716881&p=25604204&Sequence=0" border="3"></a>The opened knife overall length (parameter A) I have measured between two the most distant points on the knife body.
The blade length (parameter B) I have measured as how deeply the blade can be plunged into the target. In another words this is the distance between the blade tip and the most protruding handle's point in plunging direction. Sometimes it caused curious results, the BENCHMADE Model 730 Ares blade length and as result size efficiency was noticeably affected with handle's hump forwards near blade spine. If I would measure blade length along point-pivot axis the ratio would be much more favorable. This displays that my measuring method maybe is not the best for all knives but I had to choose one and to measure all knives according the same.
The edge length (parameter C) I have measured along the edge which is really able to cut, following all it's curves and recurves (of course excluding serration curves). Tanto blade edges were measured including fore-edge. So please do not be surprised with the fact that some knives may have edge with the same length as the blade or even longer.
I have rounded up all measurements to whole millimeters and all calculated results to two decimal places. Think this precision grade is quite enough for practical use. I have used knife weight data from manufacturer specifications because I have not enough precise balance at my home. I couldn't found weight factory data for few knives only, so I have weighted them in the nearest food shop. These data are marked with asterisks.
Here are results:
<center><table border="1" cellpadding="2" cellspacing="1"><tr><td valign="top"><p align="center"><font size="1">Manufacturer</font></p> </td><td valign="top"><p align="center"><font size="1">Model</font></p></td> <td align="center" valign="top"><p align="center"><font size="1">Weight,</font></p> <p align="center"><font size="1">grams</font></p> </td><td align="center" valign="top"><p align="center"><font size="1">Overall length,</font></p> <p align="center"><font size="1">mm</font></p> </td><td align="center" valign="top"><p align="center"><font size="1">Blade length,</font></p> <p align="center"><font size="1">mm</font></p> </td><td align="center" valign="top"><p align="center"><font size="1">Edge length,</font></p> <p align="center"><font size="1">mm</font></p></td> <td align="center" valign="top"><p align="center"><font size="1">Blade efficiency</font></p> </td><td align="center" valign="top"><p align="center"><font size="1">Edge efficiency</font></p> </td></tr><tr><td><font size="1"></font> </td> <td><font size="1"></font> </td><td align="center"><p align="center"><font size="1">Factory spec.</font></p> </td><td align="center"><p align="center"><font size="1">A</font></p> </td><td align="center"><p align="center"><font size="1">B</font></p> </td><td align="center"><p align="center"><font size="1">C</font></p> </td><td align="center"><p align="center"><font size="1">B/A</font></p> </td><td align="center"><p align="center"><font size="1">C/B</font></p> </td></tr><tr><td><font size="1">Benchmade</font></td> <td><font size="1">710 Axis Lock</font></td><td align="center"><p align="center"><font size="1">128</font></p> </td><td align="center"><p align="center"><font size="1">228</font></p> </td><td align="center"><p align="center"><font size="1">102</font></p> </td><td align="center"><p align="center"><font size="1">102</font></p> </td><td align="center"><p align="center"><font size="1">0,45</font></p> </td><td align="center"><p align="center"><font size="1">1,00</font></p> </td></tr><tr><td><font size="1">Benchmade</font></td> <td><font size="1">730 Ares</font></td><td align="center"><p align="center"><font size="1">125</font></p> </td><td align="center"><p align="center"><font size="1">208</font></p> </td><td align="center"><p align="center"><font size="1">88</font></p> </td><td align="center"><p align="center"><font size="1">88</font></p> </td><td align="center"><p align="center"><font size="1">0,42</font></p> </td><td align="center"><p align="center"><font size="1">1,00</font></p> </td></tr><tr><td><font size="1">Benchmade</font></td><td><font size="1">750 Pinnacle</font></td> <td align="center"><p align="center"><font size="1">125</font></p> </td><td align="center"><p align="center"><font size="1">212</font></p> </td><td align="center"><p align="center"><font size="1">93</font></p></td> <td align="center"><p align="center"><font size="1">94</font></p></td> <td align="center"><p align="center"><font size="1">0,44</font></p> </td><td align="center"><p align="center"><font size="1">1,01</font></p> </td></tr><tr><td><font size="1">Benchmade</font></td> <td><font size="1">800 AFCK</font></td><td align="center"><p align="center"><font size="1">116</font></p> </td><td align="center"><p align="center"><font size="1">235</font></p> </td><td align="center"><p align="center"><font size="1">101</font></p> </td><td align="center"><p align="center"><font size="1">100</font></p></td> <td align="center"><p align="center"><font size="1">0,43</font></p></td> <td align="center"><p align="center"><font size="1">0,99</font></p> </td></tr> <tr><td><font size="1">Benchmade</font></td> <td><font size="1">910 Stryker</font></td><td align="center"><p align="center"><font size="1">108</font></p> </td><td align="center"><p align="center"><font size="1">208</font></p> </td><td align="center"><p align="center"><font size="1">92</font></p> </td><td align="center"><p align="center"><font size="1">88</font></p></td> <td align="center"><p align="center"><font size="1">0,44</font></p></td> <td align="center"><p align="center"><font size="1">0,96</font></p> </td></tr> <tr><td><font size="1">Böker</font></td> <td><font size="1">Walter Brend Tactical</font></td><td align="center"><p align="center"><font size="1">170</font></p> </td><td align="center"><p align="center"><font size="1">225</font></p> </td> <td align="center"><p align="center"><font size="1">97</font></p> </td> <td align="center"><p align="center"><font size="1">96</font></p> </td> <td align="center"><p align="center"><font size="1">0,43</font></p> </td> <td align="center"><p align="center"><font size="1">0,99</font></p> </td> </tr> <tr> <td><font size="1">Böker</font></td> <td><font size="1">Gemini</font></td> <td align="center"><p align="center"><font size="1">90</font></p></td><td align="center"><p align="center"><font size="1">208</font></p> </td> <td align="center"><p align="center"><font size="1">88</font></p></td><td align="center"><p align="center"> <font size="1">90</font></p></td> <td align="center"><p align="center"><font size="1">0,42</font></p> </td> <td align="center"><p align="center"><font size="1">1,02</font></p> </td></tr><tr> <td><font size="1">CRKT</font></td> <td><font size="1">M16-01 CF</font></td> <td align="center"><p align="center"><font size="1">45</font></p> </td><td align="center"><p align="center"><font size="1">182</font></p> </td><td align="center"><p align="center"><font size="1">81</font></p> </td> <td align="center"><p align="center"><font size="1">79</font></p> </td><td align="center"><p align="center"><font size="1">0,45</font></p></td> <td align="center"><p align="center"><font size="1">0,98</font></p> </td></tr><tr><td><font size="1">CRKT</font></td> <td><font size="1">Mirage Gray Ghost</font></td> <td align="center"><p align="center"><font size="1">145</font></p> </td><td align="center"><p align="center"><font size="1">200</font></p> </td><td align="center"><p align="center"><font size="1">90</font></p></td> <td align="center"><p align="center"><font size="1">90</font></p> </td><td align="center"><p align="center"><font size="1">0,45</font></p> </td><td align="center"><p align="center"><font size="1">1,00</font></p> </td></tr><tr><td><font size="1">CRKT</font></td> <td><font size="1">Point Guard</font></td> <td align="center"><p align="center"><font size="1">116</font></p> </td><td align="center"><p align="center"><font size="1">209</font></p> </td><td align="center"><p align="center"><font size="1">90</font></p> </td><td align="center"><p align="center"><font size="1">86</font></p></td> <td align="center"><p align="center"><font size="1">0,43</font></p> </td><td align="center"><p align="center"><font size="1">0,96</font></p> </td></tr><tr><td><font size="1">Ka-Bar</font></td> <td><font size="1">D2 Extreme Tanto</font></td><td align="center"><p align="center"><font size="1">85 *</font></p> </td><td align="center"><p align="center"><font size="1">191</font></p> </td><td align="center"><p align="center"><font size="1">76</font></p> </td><td align="center"><p align="center"><font size="1">75</font></p></td><td align="center"><p align="center"><font size="1">0,40</font></p> </td><td align="center"><p align="center"><font size="1">0,99</font></p> </td></tr><tr><td><font size="1">Katz Knives</font></td> <td><font size="1">Black Cat Ltw.</font></td> <td align="center"><p align="center"><font size="1">60 *</font></p> </td><td align="center"><p align="center"><font size="1">172</font></p> </td><td align="center"><p align="center"><font size="1">72</font></p> </td><td align="center"><p align="center"><font size="1">68</font></p> </td> <td align="center"><p align="center"><font size="1">0,42</font></p> </td><td align="center"><p align="center"><font size="1">0,94</font></p> </td></tr><tr><td><font size="1">Katz Knives</font></td> <td><font size="1">Special Forces</font></td> <td align="center"><p align="center"><font size="1">155 *</font></p> </td><td align="center"><p align="center"><font size="1">227</font></p> </td><td align="center"><p align="center"><font size="1">97</font></p> </td><td align="center"><p align="center"><font size="1">90</font></p> </td><td align="center"><p align="center"><font size="1">0,43</font></p> </td><td align="center"><p align="center"><font size="1">0,93</font></p> </td></tr><tr><td><font size="1">Kershaw</font></td> <td><font size="1">Avalanche </font></td> <td align="center"><p align="center"><font size="1">100 *</font></p> </td><td align="center"><p align="center"><font size="1">192</font></p> </td><td align="center"><p align="center"><font size="1">82</font></p> </td><td align="center"><p align="center"><font size="1">82</font></p> </td><td align="center"><p align="center"><font size="1">0,43</font></p> </td><td align="center"><p align="center"><font size="1">1,00</font></p> </td></tr><tr><td><font size="1">Kershaw</font></td> <td><font size="1">Boa</font></td> <td align="center"><p align="center"><font size="1">140 *</font></p> </td><td align="center"><p align="center"><font size="1">205</font></p> </td><td align="center"><p align="center"><font size="1">87</font></p> </td><td align="center"><p align="center"><font size="1">83</font></p> </td><td align="center"><p align="center"><font size="1">0,42</font></p> </td><td align="center"><p align="center"><font size="1">0,95</font></p> </td></tr><tr><td><font size="1">Kershaw</font></td> <td><font size="1">Ricochet</font></td> <td align="center"><p align="center"><font size="1">91</font></p> </td><td align="center"><p align="center"><font size="1">192</font></p> </td><td align="center"><p align="center"><font size="1">82</font></p></td><td align="center"><p align="center"><font size="1">81</font></p> </td><td align="center"><p align="center"><font size="1">0,43</font></p> </td><td align="center"><p align="center"><font size="1">0,99</font></p> </td></tr><tr> <td><font size="1">Kershaw</font></td> <td><font size="1">Ti-Hawk</font></td> <td align="center"><p align="center"><font size="1">85</font></p> </td><td align="center"><p align="center"><font size="1">196</font></p> </td><td align="center"><p align="center"><font size="1">85</font></p> </td><td align="center"><p align="center"><font size="1">79</font></p> </td><td align="center"><p align="center"><font size="1">0,43</font></p> </td><td align="center"><p align="center"><font size="1">0,93</font></p> </td></tr><tr> <td><font size="1">Puma</font></td> <td><font size="1">Advantec</font></td> <td align="center"><p align="center"><font size="1">140</font></p> </td><td align="center"><p align="center"><font size="1">189</font></p> </td><td align="center"><p align="center"><font size="1">77</font></p> </td> <td align="center"><p align="center"><font size="1">76</font></p> </td> <td align="center"><p align="center"><font size="1">0,41</font></p> </td><td align="center"><p align="center"><font size="1">0,99</font></p> </td></tr> <tr> <td><font size="1">SOG</font></td> <td><font size="1">Pentagon Elite</font></td> <td align="center"><p align="center"><font size="1">94</font></p> </td> <td align="center"><p align="center"><font size="1">219</font></p> </td> <td align="center"><p align="center"><font size="1">101</font></p> </td> <td align="center"><p align="center"><font size="1">94</font></p> </td> <td align="center"><p align="center"><font size="1">0,46</font></p> </td> <td align="center"><p align="center"><font size="1">0,93</font></p> </td> </tr><tr><td><font size="1">SOG</font></td> <td><font size="1">Jet Edge 2</font></td> <td align="center"><p align="center"><font size="1">99</font></p> </td> <td align="center"><p align="center"><font size="1">217</font></p> </td> <td align="center"><p align="center"><font size="1">96</font></p> </td> <td align="center"><p align="center"><font size="1">96</font></p> </td> <td align="center"><p align="center"><font size="1">0,44</font></p> </td> <td align="center"><p align="center"><font size="1">1,00</font></p> </td></tr> <tr><td><font size="1">SOG</font></td> <td><font size="1">Night Vision</font></td> <td align="center"><p align="center"><font size="1">113</font></p> </td> <td align="center"><p align="center"><font size="1">211</font></p> </td> <td align="center"><p align="center"><font size="1">95</font></p> </td> <td align="center"><p align="center"><font size="1">94</font></p> </td> <td align="center"><p align="center"><font size="1">0,45</font></p> </td> <td align="center"><p align="center"><font size="1">0,99</font></p> </td></tr><tr> <td><font size="1">Spyderco</font></td> <td><font size="1">C11 Delica</font></td> <td align="center"><p align="center"><font size="1">54</font></p> </td> <td align="center"><p align="center"><font size="1">178</font></p> </td> <td align="center"><p align="center"><font size="1">79</font></p> </td> <td align="center"><p align="center"><font size="1">71</font></p> </td> <td align="center"><p align="center"><font size="1">0,44</font></p> </td> <td align="center"><p align="center"><font size="1">0,90</font></p> </td> </tr><tr> <td><font size="1">Spyderco</font></td> <td><font size="1">C36 Military</font></td> <td align="center"><p align="center"><font size="1">113</font></p> </td> <td align="center"><p align="center"><font size="1">244</font></p> </td> <td align="center"><p align="center"><font size="1">104</font></p> </td> <td align="center"><p align="center"><font size="1">97</font></p> </td> <td align="center"><p align="center"><font size="1">0,43</font></p> </td> <td align="center"><p align="center"><font size="1">0,93</font></p> </td></tr><tr> <td><font size="1">Spyderco</font></td> <td><font size="1">C48 Tim Wegner</font></td> <td align="center"><p align="center"><font size="1">172</font></p> </td> <td align="center"><p align="center"><font size="1">213</font></p> </td> <td align="center"><p align="center"><font size="1">94</font></p> </td> <td align="center"><p align="center"><font size="1">89</font></p> </td> <td align="center"><p align="center"><font size="1">0,44</font></p> </td> <td align="center"><p align="center"><font size="1">0,95</font></p> </td></tr><tr> <td><font size="1">Spyderco</font></td> <td><font size="1">C55 Starmate</font></td> <td align="center"><p align="center"><font size="1">120</font></p> </td> <td align="center"><p align="center"><font size="1">220</font></p> </td> <td align="center"><p align="center"><font size="1">96</font></p> </td> <td align="center"><p align="center"><font size="1">94</font></p> </td> <td align="center"><p align="center"><font size="1">0,44</font></p> </td> <td align="center"><p align="center"><font size="1">0,98</font></p> </td></tr><tr> <td><font size="1">Timberline</font></td> <td><font size="1">Special Service</font></td> <td align="center"><p align="center"><font size="1">170</font></p> </td> <td align="center"><p align="center"><font size="1">217</font></p> </td> <td align="center"><p align="center"><font size="1">97</font></p> </td> <td align="center"><p align="center"><font size="1">88</font></p> </td> <td align="center"><p align="center"><font size="1">0,45</font></p> </td> <td align="center"><p align="center"><font size="1">0,91</font></p> </td></tr></table></center>
Using these measurements someone could calculate some another ratio if he or she would like, for ex. blade to handle or edge to overall knife length ratio and so on.
Conclusions? They are sometimes funny, sometimes surprising, but how useful they are - let each of us decide for himself. I personally was surprised that my favorite in blade-to-overall-length ratio, BM 710 Axis Lock has, sure, very high ratio but not the highest. The same ratio have pretty many another knives. Unlike quite common opinion Military has not worse ratio than AFCK. Pinnacle and Böker Gemini have the edges longer than the blades. And so on...
As I already specified, these parameters may be interesting but no way are essential for knife choice. In any rate knowing them I personally didn't change any my preference or liking...
Sergiusz Mitin
gunwriter
Lodz, Poland
[This message has been edited by Sergiusz Mitin (edited 08-12-2000).]
Here are results:
Sergiusz Mitin
gunwriter
Lodz, Poland
