- Nov 27, 2005
Just finished this one... I have only done 3 foldovers, and was having a little trouble getting the fit right, but i think I was able to finally dial it in.
My question for you guys is concerning the trim... Do you glue/stitch the trim while the piece is flat? Or do you fold it (wet mold it) first, then try to glue/stitch the trim around the folded sheath?
It seems to me if you try to glue it while flat (which is what i did), then you are having to guesstimate pretty close to the actual finished dimensions of the sheath --- this is where i ran into trouble getting the fit perfect. Also, when I soaked it to fold it over (in hot water), the sharkskin wanted to pull away from the leather, especially at the edges.
BUT, if you try to put the sharksin on after the main body is molded, it seems like stitching would be a nightmare, since the leather would already be folded (although not yet glued up with a welt.)
Not sure if that all made sense, just looking for some pointers
Thanks :thumbup:
Thanks :thumbup:
