Foliage Green Delica 4 Titanium Spacer Pictures
Bungwrench
Banned
I wanted to put up some pictures of the nice titanium spacer/spring holder that Steve (STR) made for my Foliage Green Delica 4. It's awesome and I love it. Thank you very very much Steve!!!
I wish the Delica came like this from the factory. Yet, at the same time I am glad it doesn't because then STR wouldn't be able to do cool stuff like this for us. :)
And yes, I have a SS D4 clip on the knife so there is no lanyard hole in the clip. I don't care because I don't use a lanyard on that knife. I just think the clip looks better than the factory black one. For those that wonder the Delica is a Foliage Green fully serrated model.
The last picture is what I usually my EDC as far as knives go. I figured I would throw it in too.
Lookin' good my friend. Glad you are lovin' it. They sure are a bear to make up.
Looks like I got the two I did for Dale coming back to me to get in his for him.
After hearing the fits he had I hestiate to say they are going to make assembly or disassembly any better for folks if I were to do more.
I tell ya, unless I can figure out the diameter of the barrels so I can get the right drill bit I don't want to do anymore of em.
Just too much like work. :D
Oh and thanks for the compliments.
STR
Yeah, I should add that STR did put it together for me in his shop when he made the template from my original spacer. That said, I didn't have to put it together.
Right now do the barrels fit really tightly into the holes on the liners? Was that what was so hard to do? Or was it figuring out the hole size of the rod that goes through the spacer?
After really thinking about it I am wondering if I got a drill bit labeled number 28 that is actually a #29 or something else. 3.3mm is .1299 and its not big enough so I moved to a #29 at .1360 size and its too small as well so I am hoping that the #28 at .1405 fits just right but the last one I got was too small.
Based on my measurements of the barrels that #28 should be it but the #28 drill I got to do yours never worked without reaming and the number 29 and that one didn't seem much different from each other now that I think about it. Thats what makes me wonder if it was a mis labeled drill bit or not.
If its not a #28 the only other options are trying a #27 at .1440, or, #26 at .1470 and either a #25 at .1495 or I guess I could try to go to a 3.8mm or .1496 which all just seem to me to be entirely too large since the barrels themselves measure 3.43 mm. The problem is that the shipping will cost more than the drill bits and I need to wait until I get more on my list of needs than just them. The other problem is that I am not going to be too happy if I spend the money for drills and none of them work and then get stuck with a whole box of drill bits I'll probably never need again.
Sounds like I'm whining I guess. Not my intention. I'm just trying to only get what I need and reduce the waste in my shop is all.
STR
Now see, I like that a lot.
Coming in your forum STR always gets me thinking.
I still want G-10 scales on my D'Allara...
I want a short back spacer for my Paramilitary.
But first, I want an expendable income that I can do this with. :(
One day, I will enlist your services, lol.
STR,
Just for your information I took my D4 apart to see if it was easy to put back together. I had no problems at all. It fit really well. It was quick and easy.
I did it because I wanted to view the "lockup" of the knife. Locks up perfectly. :)
Yes the lock up on all of the ones I've seen and even the older Delicas has always been very good. I know a lot of guys using D4s pretty hard too and they love that knife. I think its a historic best seller model for Spyderco for good reason. Many much larger competitor knives that have been tried and true much loved knives for folks don't have as good a lock up as the smaller D4 does.
Some of the other mid locking knives I've seen the insides of like the Native, Endura both the E3 and 4 models, Pacific and Atlantic Salt/93mm Rescue, as well as some of the other medium duty knives by Spyderco most often have what I'd call some very assuring looking lock ups too. Not that they don't have issues now and then with a few but based on the number I've seen and done surgery on at this point I'd say their % of doing it right is higher by far than the few bad ones that slip out.
I think many folks believe that I love Spyderco so much because of the way the Spydie crowd supports me but the truth is I was carrying and using Spydercos long before I did my first rebuild of one. But after seeing the insides of more than I can count for folks sending them to me to put custom handles on I know it was the right choice. You can trust their locks more often than not. That is how I judge them now and for the most part how I judge other company knives, by seeing them intimate like on the insides. Comparing the Spyderco and Cold Steel lockback to other lockbacks changed my idea of what was a good lock up vs what would get by to be honest with you. Thanks to their knives I like to think that I moved the bar up a notch or two when I make one of my own lockback folders.
I should say this also speaking of the lockback type folder since someone brought it up with me privately after that "Good Lock Thread." It is true that I have not taken apart as many competitor knives as I have Spydercos and Cold Steel knives but at some point I have had all the other major and some minor brands apart enough to see more than one example of their knives for the same models as well as some that repeatedly show up here for jobs that require me to break them down. Once apart I can then see what was going on inside it naturally.
What is funny about this is that in my mind the competitors lockbacks more often than not have a higher % chance of not really impressing me all that much with their folder's lock up and yet I've taken fewer of them apart. In their defense though, this does not mean that their locks don't work. Obviously they do and with little trouble in normal use for many folks. The question I ask myself when I see one vs the other is simply which I would trust more for those times when it isn't normal uses you are stressing the lock with and also which lock I'd trust more with my fingers in the path of the blade should it close accidentally during one of those abnormal times. To me its a no brainer. I stick with the odds in my favor knowing what I know.
STR
