- Dec 28, 2003
I wanted to follow up on our storage thread from some time back with some pics of a solution I came up with after hearing from several of you and looking at the pics that Sweet posted particularly.
(I just got the camera and am learning how to use it so hope the pictures come out OK. Hopefully I can figure out how to attach them as well!...)
What I did was use the corner space next to my current display cabinet. The space usilized is just 15" X 15". I took a piece of yellow pine about 5" X 15" and drilled 9 flat bottomed holes using a 1.25" Forstner bit. Then cut 9 pieces of the same diameter poplar dowel cut to 15" long and glued into the holes using Gorilla glue for strength. I cut a 30 degree front bevel on each dowel first before installing, for looks and it also makes it easier to slide the blades in from the front. Added a 2" zinc plated screw into the backside of each dowel to suck them up tight. (Drill a pilot hole 1st.) The glue expands as it dries, and swells out the sides and back of the dowel. After it dried I scraped off the excess, and then finished with 2 coats of Minwax wiping stain and 3 coats of semi-gloss polyurethane.
I placed all the dowels equidistant to each other, except for the last pair furthest to the right as viewed head on. Those I butted right up against each other and then used a shark saw to make a smaller slot between them. Good for thinner blades.
It's definitely low tech, but only costs about $12 in materials to build and does the trick for me. The pics don't show any khuks on it, but I have put a dozen average sized khuks on it with no problem. 12" to 20" sirus and kobras and GS's, Chitlangis, WWII's and all the medium sized blades fit fine. I would have to have more space between the dowels for the big AK's and similar stuff, but I didn't build it for that. Right now it is holding about 14 or 15 of my non-HI fixed blade collection, with room for about that many more.
Nice thing is it is out of the way and using corner space that would not be used otherwise. Like I said, it works for me and at least might give you some ideas, or YMMV.
Regards,
Norm
Regards,
Norm
