food wrap
Are there any problems wrapping knives in food wrap plastic after they have been wiped with Tuf-Cloth for storage?
mobeetie08
What purpose does the wrap serve? I think it is pretty much safe to just wipe them down and store them as is.
I would think wrapping in plastic would trap any ambient moisture causing problems.
Yep. Rather than being useful for keeping moisture out, wrapping it will only help to confine moisture and keep it right next to the steel.
Use VCI [volatile corrosion inhibitor] paper .With that inside a zip-loc bag I've never had a problem.
I've also been storing mine in clean Zip-Locs for 20+ years now, with a caveat: make sure the knife is completely clean & DRY before putting it in. No moisture, fingerprints, dirt, acids or salts on the steel. Carbon blades might still patina a little, from exposure to oxygen in the bag. But, that black oxidation actually helps protect the blade a little bit. I'd be less inclined to use plastic wrap, because if there are fingerprints (holds salts & acids), particles of dirt or whatever on the blade (dirt holds moisture, acids & salts), it'll trap it directly against the steel. This is the same reason why you don't want to store a knife in a sheath, due to the trapping effect of direct contact. A little air barrier around it would be a better thing, in that case.
As was mentioned, some dessicant in the bag might be good too, if you live or store your knives in a humid area.
I live on the Northern California Coast a couple of blocks from the ocean and I am getting spots on some blades. Would the wrap trap more moisture and cause more damage?
Definitely. Humid, salty air. I'd focus on keeping the blades as clean as possible, with frequent wipe-downs. Some oil or other protectant applied onto the clean blade might help too.
when i ship a knife i made, i wrap it in saran wrap that has been sprayed with wd 40 after i spray the blade. for long term storage i woud go with mete :D.
