- Dec 30, 2008
I've been sharpening knives for 25 years, but convex always made me nervous. I can freehand sharpen (not to a perfect accuracy but the knife has always been sharp) but mostly have used a spyderco sharpmaker or more recently a wicked edge system. I got a khukuri from Kailash blades and put it to use. Well, one day the blade met a rock under the dirt as i was taking down a sapling. I tried to put a V edge on with my diamond stones and succeeded for the most part, but it wasn't the same. The recurve in the blade also was not easy to address. So, i sucked it up and bought sandpaper. 400-600-800 and did a final polish with some 2500 i had laying around that i forgot about. Normally, i'd step up 1000-1500-2000-2500. The 2500 was really more of a strop than for anything else. Anyways, i used a kneeling pad as my backer and the wet dry paper and went to work. 400 produced a good edge but i decided to go all the way up to the 800. I also noticed more of a burr form than i had seen with any other knives which was cool. Much larger wire burr. Anyways, the blade push cuts now even in the recurve. For the recurve i took a round Wera tool roll i had and wrapped the paper around that. So... if you're nervous about convex and have at least some idea as to blade angles on a flat stone, give it a try. I'm very impressed with how easy it was and how sharp the blade is now. It's much sharper than necessary for the tasks at hand, but who doesn't want a blade sharper than necessary? Is there even such a thing?
