Gday Cotdt and others,
Please find below some info to help make decisions about your heat treating process when using s5.
Also while Ive previously talked about how S5 was specifically designed to have maximum hardness, toughness and strength as a tool steel, there is another mechanical property that can be objectively tested that's useful for blades. While engineers figured out how to measure things like yield strength some time ago in classical solid mechanics, it took many deaths and machine failures before the true natural of dynamic mechanics was properly understood.
Specifically for example, the stress of a part in ultimate tensile strength is not the be all and all end. When the dynamic condition of smaller stresses go "on and off" it can break the part well before the UTS is reached. Its even worse when the stresses reverse, to whats called reverse cyclic fatigue. In fact some materials are so hopeless with fatigue that the stress of feathers onto it will eventually crack it (it will take ages though heh).
Whats good about materials like S5 is the silicon content provides excellent fatigue properties. Other materials use this too, such as 9260 spring steel which isnt as good for tool steel applications as S5, but is nonetheless designed for spring applications where fatigue is a big issue.
Anyway best of luck with your experiments. cheers
