Well , tension spring for tightening belt works .Gas spring works even better and ratchet is best , right ? What do you think about this simple modification on this kind of grinder ?Should work with steel spring and with gas spring ? So simple to do and all you need to do it is to tight that bolt after you put belt on ? Grinder should work same as you have best ratchet tension on the world ? I cant find clear picture on net of KMG from that side so I draw this .I think it is clear what I mean ? I can t see any reason why this should not work ? Only one more bolt to tight before you start grinding ? You can use that handle for bolt , I forgot how you call it .............. ?
