- Aug 16, 2008
For sale are three Beretta BH Tacticals. Two 3.25 and one 2.25. All made by Fox Italy I believe. Harsey design. All CPM S30V Blades, bead blast it appears.
All three never carried, original everything. Just taken out of the box a few times for show and pictures.
I believe the liners and clips are all titanium.
One large has a little side to side play and needs the pivot tightened. The other large is rock solid but could actually use the pivot loosened a tad. If you look at the blade centering pictures you'll see the loose one is a tad to the left looking at the tip and the tighter one is a tad to the right looking at the tip. Adjustments would likely center the blades more. The looser one opens easy and can be flicked, the tighter one opens just fine the way it is but could still handle a slight pivot adjustment backwards. Heat the pivots up and adjust. I just never got around to it because I never used them.
The small knife is perfect in every way. Centered blade and perfect pivot adjustment. There is a Beretta Warranty return card in the small knife box. The two large came without one. The knives are warranted against any defects or MFG flaws.
Lock up is early on all.
I paid $99 each for the two large and $89 for the small, all plus shipping. SOLD
First I'll take them gets them.
Here are some pictures:
