For the ABSOLUTE finest smoothest most polishedest edge, you must learn to use an........AIR STONE..........
Yes, this ancient technique has been passed down to only the very select few and I am about to divulge it here PUBLICLY.
Get a box of air. The air should preferably be very pure air and as clean as possible. Put the box in the fridge. This will make it denser.
After a day in the fridge, take the air out of the box and set it perfectly level on the working surface. Then using quick strokes (and trying not to disturb the dense air which will try to mix with regular "room" air stroke the blade at a measured 18.03 degree angle in both directions.
You should try for a minimum of 20-30,000 strokes over several days.
If the polish is still not to your satisfaction, go one step further and put another box of air in the FREEZER and repeat.
NOTHING will give a finer edge.
