- Apr 13, 2017
Hello everyone, I have a special order for a friend of my nephew who wanted a gray blade. I have fooled around with etching but never delivered a finished blade. Mostly just post HT "decarb softening" in diluted muriatic acid from the pool store. Well as you might expect I'm getting streaks and uneven results. Had some luck in the search engine but here's what I've done:
80CRV2 hand sanded to 600 grit at 60-61, cleaned with soap/water then wiped down with denatured alcohol. I wore clean white nitril gloves while handling.
The acid is diluted probably at least 5-1 with tap water (softened water common to the desert SW US). The solution is at least 2 years old in a capped 4" PVC pipe.
So I've seen where Stacy in an old thread said to use 400 grit, also seen people say to "swish it around" maybe? Are there any other recommendations? TIA!
P.S. he wanted a gray wood handle too and what I've done so far is use water soluble coal black leather dye from Tandy, diluted with water to achieve decent results on that.
