- Sep 23, 1999
I just read Rotor's thread asking for a source for fire brick and an idea popped in my noggin. Isn't it true that heat cannot travel thru or in a vacuum? If so, why couldn't you take a piece of pipe, weld some plate steel on one end that is bigger than the pipe. Then cut the center out to give access to the pipe. Now slide a larger diameter pipe over that assembly and weld the it to the plate with the inner pipe as centered as possible. Make the inner pipe about 2" longer than the outer. Cut a hole in a plate thats just big enough to slip over the inner pipe and weld it to the inner and outer pipe. Then drill and install some kind of nipple that you can hook to a vacuum pump and draw a vacuum between the pipes. That would suspend the inner pipe, except for the ends, in a vacuum. This a load of bs or ya think it has potential???
Take care!! Michael
Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!
http://www.nebsnow.com/L6steel
Buzzards gotta eat, same as worms!!!
Take care!! Michael
