I have dabbled in knifemaking mostly using old files and heat treating with rosebud torch with hit and miss success (on the heat treating part). I have always wanted a forge but either been to cheap or not had the time. The art department at the high school where I am a shop teacher just threw two large kilns in the dumpster. I used the forklift to get them out and salvaged most of the ceramic fiber bricks out of them. So, I have half a pallet of ceramic fiber bricks sitting behind my shop right now and I am thinking it is time to make a forge. I have been doing reading online and watching YouTube videos and I think I am more confused on what I want than when I started researching so I thought I would ask advice with some specific questions.
First of all, I am a shop teacher with access to a CNC plasma table, welders, and other metal working tools. At home I have a metal lathe as well and a 2,000 square foot shop so I am pretty capable in the fabrication area from both a skill level and equipment standpoint. I was thinking about making a steel rectangle tube to put the brick in. I have a bunch of 5/16 plate sitting around so I will probably use that though thickness should not really matter for the shell. I would like a ribbon burner but that seems a bit outside the time I have available right now so I would probably settle for two or three venturi burners which I would of course make myself. So...
1. Do I need to line the ceramic fiber blocks with a hard fire brick?
2. Do I need to use a mortar or can I just set them in tight together?
3. Do I need to coat them with anything? Some sources talk about putting some kind of coating on them to keep fibers from escaping.
4. Do I want the burners aiming straight down on the surface where the steel will be or angled a bit. It seems forges are made both ways.
5. How big should I make my fire box? I was thinking about having it be about 14" long but I am not sure about how wide and tall. I plan to make machetes and kukris so I do not want to go too small but I do not want to be too big either. I would have a removable back so I could pass stock all the way through if needed.
6. It seems a lot of the DIY forges are round... will my box type design get the job done?
7. Anything else I am not thinking of?
I have way too many projects I am working on such as a power hammer, a power hydraulic press, a pizza oven/outdoor kitchen, oilfield pipe fencing, and a gatling gun which is on the 10 year plan.
