Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
Today I had to try to explain about the different types of flames to an apprentice jeweler. I showed him on paper how the ratio of fuel to air affects the weld and the metal.In welding gold,silver,and platinum it can make an enormous difference.
I thought some of you might like to see the same things as they refer to a forge running on propane.
When you burn propane, C/3H/8 , with oxygen, O/2 you will get one of three tings:
A NEUTRAL FLAME
AN OXIDIZING FLAME
A REDUCING FLAME
If the ratio is properly balanced
C/3H/8 + 5O/2 =3CO/2 + 4H/2O
Water and carbon dioxide. This is a neutral atmosphere that give the most heat with the least waste. The affect on the metal is to keep it pretty much as it is.
If the ratio is high in oxygen (more air)
C/3H/8 + 6O/2 = 3CO/2 + O/2 + 4H/2O
There is excess available oxygen in the atmosphere that will combine with any available element,like red hot iron,chromium,carbon,etc. This will create pitting, oxides,decarb,and several other undesirables. It can alter the alloy of the steel.
If there is a lack of oxygen (low air volume)
2C/3H/8 + 11O/2 = 6CO + 16H/2O
The lack of oxygen creates carbon monoxide and water. This will allow the hot gasses to combine with any available oxygen,such as the oxides on the metal,leaving a cleaner surface. It will also keep the iron and carbon in the steel from oxidizing,thus preventing scale and decarb.
For general work you want a neutral atmosphere. For welding a slightly reducing atmosphere.For melting or attaining the maximum temperatures, an oxidizing atmosphere.( in general ,you never really want an oxidizing atmosphere when making knives)
Most forges are set with a slightly reducing atmosphere. The thing to keep in mind is what is happening as you turn up/down the blower or the gas.
For some of us it has been a few years since High School Chemistry.But remember when the teacher told you,"Some day you are going to need to know this stuff." Well..............It couldn't hurt.
Stacy
PS: Wish I knew how to use subscripts and superscripts on the computer.Must be one of these buttons?
A NEUTRAL FLAME
AN OXIDIZING FLAME
A REDUCING FLAME
Stacy
