Tanguay Custom Knives's Avatar
Tanguay Custom Knives Tanguay Custom Knives is offline
KnifeMaker
If its a simple hunter/skinner knife, here's what I do:
Safety:
First, move all combustible materials out of the area.
Next, make sure you have a fully charged fire extinguisher onsite before starting.
Third, make sure your oil is in a fireproof container (read metal) and you have a fireproof lid that fits tightly.
HEAT TREATING 0-1 TOOL STEEL
1. Preheat oven to 400 deg f.
2. Mount torch in vise. Attach #7 or #8 tip.
3. Tape magnet to torch so it rides close to tip, but in the cold zone.
4. Fill adequate size bucket with old motor oil.
5. Preheat oil to 140 deg f. by dropping in a red hot bolt, or something with
enough mass to heat your oil.
6. Slowly heat the edge portion of your blade until cherry red, and non-magnetic.
7. Quench the edge in oil. Do not swirl until boiling stops. Leave blade in the oil for a few minutes.
8. Remove when just cool enough to touch.
9. Test edge with a file. It should slide right off and not cut. If it doesn’t, repeat the process.
10. Wipe off all oil, and immediately (while still warm), put in kitchen oven for one hour.
11. After 1 hr. remove blade (leave oven on), and allow it to cool to room temp. (takes about 20 minutes).
12. Put knife back in the oven for another hour.
13. Repeat for a total of 3 cycles in the oven.
14. Your blade’s edge is now hardened and tempered to about Rockwell C 60-61. The rest of the knife should be flexible enough to give a little without snapping in half.
__________________
I followed these instructions and the file just dug right in the knife. I am using a forced air burner forge I.G style, front and rear insaboard doors,kawool,itc-100,vaccum cleaner as a blower. The one part of the knife that the file did slide off was the tip. It made a differnt sound on the tip of the blade, compared to the main part of the blade. Canola oil in an ammo can is what I am using a quench.
