I just put together a tutorial on build a forge and have a parts listing on the plumbing. I have the part numbers for regulator and valve. Darren Ellis will have it on his site.
This is part of it. Have plenty of pics too.
This is basically what I like to use for my welding forge. Forge body at least 8” diameter pipe 14” to 18” long. The best use I found for railroad spikes are for the legs on the forge.
I start by welding the legs on the body. Next is to cut a 2” piece of black pipe 4” long and cut on an angle to match the curvature of the body also drill a hole to hold a 3/8” bolt for the set screw to hold burner. I just weld a 3/8” nut to the pipe. The placement of the burner should be 1” to 2” off center and at a 10 O’clock position (see attachment1) Place the angled end to the forge body and trace around it and cut it out with a torch.
Forge body is lined with 1” thick Inswool coated with ITC100. The floor I put in the ½ brick firebricks one of them must be cut to size. I also fill in the gap between the brick and wool with kitty litter then coat it with Satanite. I have yet to eat through a brick with the flux.
The burner consist of 1 ½” black pipe see below for listing and attachment 1. I drill a ½” oversize hole in the 90 degree elbow to fit the ¼ npt pipe. The pipe is welded into place. The cap is drilled with a 1/8” hole in the center and applied to pipe. The injector hole will vary depending on your altitude. The coupling must have the outside diameter ground small to accommodate the blower.
Gas line consists of regulator with gauge, needle valve, ball valve, male fitting into tank and quick connects. I use quick connects with Oring seals in them. The way I plumb it is in the following manner. Male fitting into tank, ball valve, regulator, needle valve, hose and quick connect. I use a ball valve is case I must shutoff the gas quickly and the quick connects so the gas setup can be remove and used on another forge.
Forge Parts
Blower Part # 16-1032 $18.99
Vendor Surplus Center
Phone Number 800-488-3407
Black Pipe
1.5 inch
Nipples
6” & 4”
90 Deg. Elbow
Coupling
Gate valve if using needs 2 nipples
¼ npt nipple 6”
¼ npt cap with a 1/8” hole drilled in the center
Ball valve for gas shutoff
Male fitting for propane tank
8’ of hose
MSC 800-645-7270
PAGE# ITEM# DESCRIPTION $$$$$
3941 08557852 NULINE REGULATOR with gauge 28.75
4061 00075390 NEEDLE VALVE FEMALE 1/4 NPT 20.62
4061 00076042 NEEDLE VALVE FEMALE 18.48
1/4 NPT SMALLER IN SIZE WILL DO THE SAME AS ABOVE
