Forge lining, ITC-100 question.
Hi all,
I got my forge built, lined and coated with satanite. My question is should I fire the satanite before applying the ITC-100 or just coat it and fire both together?
Thanks,
John
I am not sure that it matter either way. I just coated mine with ITC 100 over the Satanite that was already there.
I also used ITC 213 on the burner element and then cat litter in the bottom.
Originally posted by John Tomson
Hi all,
Thanks,
John
Hi John,
I usually recommend heat curing 2 to 3 coats of Satanite and then coating with the ITC-100, tends to make for a robust coating. Let's see a pic of that forge when you get it done! :)
-Darren
Also, I'm trying to get the plumbing setup for this. What regulator should I get, will just a barbeque regulator work or is something more professional required?
Thanks,
John
My [edit]adjsutable high pressure[/edit] regulator works great on my burner.....
Darren built it! :D
Tom
Whoa Tom!!!:D :eek: :D , that's not a BBQ regulator on there per se, it's an adjustable high pressure regulator...a BBQ regulator wouldn't supply enough gas for a forge! :)
Hi John,
Go down to your local gas supply and ask for an adjustable (0-20 psi) regulator...should be able to find one for $25 or less depending on style...I'm looking at getting set up as a distributor for various gas forge parts (regulators, fittings, etc.) but currently don't carry this stuff...hopefully in the near future...
-Darren
Darren
Whoops, Sorry! It "looks" just like the one on my grill though. I thought the adjustable high-pressure regualtor was like the one with the guage on your vertical forge.
Again sorry, I was basing that solely on what it looked like.
Tom
Tom
Hey Tom, They come in many shapes and sizes. :D
You coming up this way for Harley's Hammer-in next month? If so let me know, we can meet at my place and drive up together if you want... :)
-Darren
Originally posted by Michael J. Spangler
listen to darren ellis he's the man!!! and buy your products from him to!!! very good service
I have to agree. Darren went out of his way to help me with locating some refractory material I could not locate anywhere else. A class act.
