forge lining
I have decided to go with Kaowool/ceramic blanket for my forge lining. I understand the arguments for castable, but I will be the only one using this forge(s) and will be making little pattern welded material for the time being.
That said, I have been hearing of people going with 2 and even 3 inches of kaowool, claiming that the savings in gas well makes up for the initial cost and continual bulkiness of the forge.
Has anyone here compared the thermal efficiency of 1 vs. 2 vs. 3" kaowool linings?
Also, has anyone compared ITC-100 to Satanite (or any other coatings for that matter)?
Thanks,
John
John: I only use 1" of the wool with the ITC-100. My forges are the only ones that I have used. I have had my little forge up to 2800 deg. (burnt thermocoupling) You have used my smaller forge what do you think, compared to the other ones you have used. I have tried the Satanite, but like the ITC better.
Hi John,
One way to go is with 1" Kaowool and coat this with a healthy coat or two of Satanite. Then, after the Satanite has cured, apply a thin coating of ITC-100. Satanite is cheap, cheap enough to use as a mechanical refractory coating to protect the Kaowool. ITC-100 is fairly expensive in comparison, use it in a very thin layer for its refractory properties only.
I don't know of any *real* experiments comparing Satanite to ITC-100, at least ones that yield quantitative results. However, the pottery community are probably the biggest users of ITC-100 and the positive effects are noted by many of them in their heating bill. If I ever get enough free time, I may do some measurements and put up some hard data on a web page for a comparison....but things are a bit busy at the moment so it may be a while.
If you need any refractory materials in small quantities, I sell them on my web page, let me know if I can be of any assistance. :)
http://StraightRazor.net
-Darren
