- May 1, 2011
Hey guys, I just made a forge from a stove pipe with 1/2 inch thick insawool around the inside. I ordered it as 1 inch thick but the tube would seem clogged if I put so much in. So it started out 24 inches long, and I had one mapp gas burner and one end sealed with the insawool. I cut it in half this morning, so I have a 12 inch tube with 1/2 thick insawool around the inside, with a pretty bad job of a satanite coating on the inside. I have been trying to use 1 Mapp gas torch as a burner, I just stick the whole head of the torch in there and the flame is inside the pipe itself. When reading stuff about these gas forged a while ago, I remember something about how far away the torch needs to be. I can't seem to get my steel hot enough. Even if I plug up the ends with insawool. Should I need another torch? The tube is 12 inches long, and the diameter inside the insawool is only 3 and a half inches. How long should it take the forge to heat up? How far away should the burner be?
