- Sep 3, 2010
Everyone,
I am loving this hobby and am spending more and more time on it every week. I am ready to spend some more money on it, and the only real choices were a grinder and a forge. The first things I would think to need would be a bandsaw and a drill press, but my angle grinder works just fine, and I have access to a mill-that-doubles-as-a-drill-press. I was thinking grinder, but I realized that it would be hard for me, with a relatively small amount of income (not by choice) to keep myself supplied with belts. refilling a 20# propane cylinder every couple of months would be more practical. besides, who doesn't like smashing hot steel? here come the questions.
1. I was thinking about the choice between a horizontal and vertical forge. I have a horizontal and it seems that it is really hard to keep it from having hot spots. also, a vertical allows you to HT things of any size, and becuase I won't be heat treating anything over about 12 inches, then I think I would be just fine. however, I am not sure if the horizontal has any serious advantages that I should know about.
2. should I go for a venturi burner or a forced air burner? I think both work, but I am not sure if one has any serious advantages. I am going for simplicity, and so one burner is the limit unless you can convince me that 2 is just as easy, easier, or totally worth the effort.
3. I am going to be basing my forge off of this: http://http://www.dfoggknives.com/forge.htm. can I get away with 1 inch of wool, 1 inch of castable refractory and ITC 100?
4. I heard that if your run a forge off of a 20-25# cylinder of propane then you will freeze the tank after any length of time. is this realistic?
5. as far as anvils go, I have a chunk of railroad track and and a 5x2x17 chunk of 4140 that I have available. what was I was thinking was grinding the top of the railroad track flat and then welding the 4140 on top and using it as a little anvil. are there any problems with this?
6. I will have all of this on a cart. I would like to fabricate it if possible. what would you suggest?
EDIT: forgot to mention budget. I am thinking spending 200-250 on the project.
there will be more to come. thanks,
Steven
Steven
