- Nov 27, 2013
Alright, the time has come. I’ve been needing to build a larger forge for a while now and I wanted to double check with you guys to make sure I have everything I need. I wanted to get enough supplies and materials to build at least one forge, but possibly two, and be able to fix/replace things when needed.
First, I’m going to build a large horizontal tube style forge using either a propane tank or a section of steel pipe. Second I’ll probably do a vertical forge with a similar diameter. Both will be blown forges. I will probably do a ribbon burner at some point, but for now, they’re just going to be a regular blown forges. I’m planning on just using Kaowool lined with satanite, and then maybe some Bubble Alumina Refractory Coating on the floor for extra flux protection. If I use the satanite, do I need to use rigidizer? Or will it even work on top of the satanite? Or would I put it on before the satanite?
I’m just going to buy a blown forge burner kit from High Temp Tools, to keep it simple. They say I only need a propane hose, regulator, POL fitting, and blower to complete the burner. I added all these to my list(blower from a separate site, see below), but what tubing would I need to run the blower to the burner? Is that something that can be sourced locally? If not, does anyone know if HTT sells it? Also, are there any other valves, flares, MiG tips, or other things I’d need for the burner or forge? I’m only worried about putting together one burner at the moment and will probably source parts separately for the vertical forge locally, since I will pretty much know what all I would need after doing the first one.
So, here is my list. I wanted to add the castable refractory, just in case I decided to go that route in the future, and also for a ribbon burner. There’s Mizzou and this Kast-o-lite 30 stuff. They say that the Kast-o-lite stuff is better, and it’s not much more expensive, so I went ahead and just put that on the list. Should I get the Mizzou instead, or is the KOL good to go?
Here is my list:
As far as my blower goes, this is the one I’m looking at. I’m kind of towards the top of my budget so I’d like to not spend much more than around $100 for the burner if possible. Less if if there’s a decent one available.
Any advice or opinions you guys could give me, would be greatly appreciated. Anything I should add, or remove to the list also. I’d kind of like to just get some 1/4” thick walled, 10” diameter or so steel pipe to make the forge body out of, but am not sure where to get it from. Does anyone have advice as to where to find something like that? I have a compressor tank that will work, but I’ll need an additional tube for when I make the vertical forge. Again, any help would be appreciated
Here is my list:
