I made damascus by hand for 7 years, with billet sizes up to 4 lbs. Getting the weld set does not take a great amount of force. Its the drwaing the steel out that is the work. I would set the weld and draw it a bit with your regular hammer and then work it down to close to thickness with a crosspeen.
Page I am surprised at your response after seeing you go at the steel like a madman.
Del
Del is your man when it comes to damascus billet knowledge. As Del said don't slam your first second or third tack on a weld. Welding is a gentle caress with the hammer in the center of your billet. I like to do one gentle hit with my favorite hammer in the center of the billet and put it back in the fire to let the grain structure set across the weld, then one hit on each side of that one, also gentle as can be, reflux, back in the fire, hammer gentle shots in a spiral pattern from center to edge, back in the fire, then once I have covered the entire surface in gentle taps, always straight through the billet perpendicular to the anvil surface (so as not to shear the new structure), then I start to get a little more persuasive. Following that routine, it always sticks, no obvious voids in 4 plus years.
Del, I am a madman, but there is a method to my madness. I made a 160 layer billet before breakfast (literally, I fired up the press at 6 am, breakfast was about 8:30) at the hammer in at Indian George's on his press, and made 4 more billets before I left. If I'm going to get serious I need to build serious equipment.
True story there! Page is a beast with a hammer! Start small and have fun, don't try to bully the weld, if it is at temp, it will only take easy swings to set the weld...After that is when you put the "hammer down" and draw the stock out. Good luck and show us some pictures when it is done
BTW, Del...good to see you upgrade.
Mike
Oh yes, BTW my favorite hammer mentioned above is an antique 4 pound straight pein. That doesn't mean that I hit hard until I am drawing out, on the contrary, until I have tacked the entire billet, I am literally hitting it just hard enough to bring the metal together, that is all it takes, just a love tap. My hammer for one-hand drawing billets over an inch and a half is a 3 kilo Peddinghaus straight pein. Working by hand you don't want to start more than an inch and a half by 4 inches until you have practice. every inch over 4 inches adds about 30 percent to your difficulty until you have a couple billets experience
Good luck, and remember, pictures or it didn't happen (actually pictures help us troubleshoot your process if you hit any snags)
-Page
