Recommendation? Forged firestriker
I posted this in the Outdoor Gear, Survival Equipment & More section with no responses. I'll try here.
I want to find several of these, preferably forged by a forum member. Will you please give me recommendations? Thanks.
You could try posting in Services Wanted. It is in The Exchange.
You never filled out your profile, so no one knows where you live. That makes it hard to give an location accurate recommendation.
I have seen them show up in Gargets and Gear in The Exchange, too.
Basic Info:
Six to eight inches of 3/8" Square stock in 1095 or W1/W2 is what I have used. Old files also work very well as the stock material. Another stock size that works well is 1/2X1/4".
Forge the striker edge to about 1/8" thick and make sharp outer corners on it.
Draw the rest out in a taper, curl the ends., and curve/bend/shape the bow to fit your hand.
Brine quench and temper at 400°F. Torch draw the temper back in the handle areas.
A TIP for those who never used a striker -
You strike the stationary metal striker with the moving flint/chert. Most folks try it backwards and end up with cut knuckles and no fire. It is shavings of the metal you are shearing off, not bits of stone.
I guess I'm not clear what you're asking. Are you looking for buying advice? or advice on making them? I've made quite a few over the years. Mine tend to be simple shapes with one hardened edge. The last couple I made used 1920's Ford Model T springs, and threw some amazing showers of sparks.
Nate, I am looking for forum members who forge them so that I might consider a purchase.
